Calculates the actual time-to-live (TTL) value used in the LLDPDU messages.
The formula is transmit-interval * transmit-hold; by default the TTL value is (30*4) 120 seconds.
| hold | Used to calculate the TTL value; the range is 2 to 10. |
4.
N/A.
The following command configures the transmit-hold value (which is used to calculate the TTL of the LLDP packets) to 5:
configure lldp transmit-hold 5
